2019 QX80 rear hatch will not open automatically
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
mamat
Car: 2019 Infiniti QX80
When I bought by 2019 QX80 the rear console was not secured. What type of screw do I buy to secure the console? Also, recently my back door will not open automatically without pressing the button in the car or the key fob; the handle clicks but doesn't move the door. Any suggestions? Thanks!
Reason: Revise Title
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Sounds like you accidentally turned off the liftgate Main Switch by your left knee. The p/n for the rear console screws is 01454-N5041, if I remember right they're 6mm (10mm head).
Ilya
Moving this to the correct forum.
adamruiz2001
Car: 2011 Infiniti QX56
If it turns out that you didn't by chance turn the lift gate button off on the left side of the dash by your left knee, if could be the electric accuator that lifts the rear gate. Hopefully not, but it happens. Keep us updated on what you find.
VStar650CL
Technical Expert
adamruiz2001 wrote:
Tue Aug 30, 2022 4:42 pm
Since it opens with the fob but not the handle, the actuator works and can't possibly be causing the OP's issue.
adamruiz2001
VStar650CL wrote:
Tue Aug 30, 2022 4:48 pm
Oh, I took it as it didn't work with the key fob, inside button or lift gate button...
Return to “Armada Forum / QX56 Forum / QX80 Forum”
