FS2018 »
https://forums.nicoclub.com/fs2018-u316423.html
Sun May 04, 2025 5:43 am
when the key is inserted, the lights and evertything else is on but, when the key is turned to the start position, there is no single click or anything else, the staryer does nothing however, the car has been taken to a ceritfied service center and ther is no problem with the starter or the wiring to the starter. Also, a new starter was installed in August 2024.
The car has failed 3 times with the the same symptoms, each time the starter does nothing but, a day or 2 later it will start. The problem only happens when the car is parked in the driveway, on a weekend and what appears to be on a shedule. The car has not failed to start anywhere else, work, or ball games or store etc.
The most recen was last Saturday, the car was towed from the driveway to a different service center and the car started and nothing was changed. And, again evrything was tested and retested and started 20 times in a row without any problems.
Possibly, the Key FOB?
