2018 Nissan Rogue CVT Fluid Replacement Procedure
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That is a whole lot of time in the seat. ;)
MrX.
Car: 2014 Nissan Rogue SV AWD
PowerslavePA wrote:
Mon Jun 12, 2023 12:48 pm
MrX. wrote:
Sun Jun 11, 2023 10:54 am
I don't see any mention of the required filters here. Anyone have part numbers for the filter or a good website I can look them up on?
Amazon has a three pack:
https://www.amazon.com/dp/B0BNCFSLC5
It is a cartridge filter, just like a cartridge oil filter.
Thanks a lot for the info! I will try and take some pics of mine. 260k KM current, CVT drain at 90k, 170k, 240k but pan never been dropped (all dealer records state drain and refill)
Hauled a heavy-ish trailer across the continent just a few months ago, so I feel it's the right time for a full service.
Boulder.rogue
Car: 2021 Nissan Rogue
Hi guys planning to diy transfer case, differential and cvt fluid change, but can figure ut out which is the drain plug and fill plug of my transfer case, and leveling fluid of my cvt. I have 2021 nissan rogue awd by the way. please guide me posted a photo below.
thank you!
VStar650CL
Technical Expert
Here's the CVT leveling plug, but I don't recommend using it unless your transmission leaks or you want to calibrate a dipstick. Otherwise, just drain into a see-through bucket and mark what you drain out, then refill that exact amount:
It's a little difficult to orient on the transfer case because your pic isn't panned out far, but here's the fill plug drawing from the FSM. Refilling is like a standard rear end, fill to the bottom of the hole. Make sure the car is level:
PowerslavePA
Car: 2016 Nissan Rogue SV AWD w/Platinum
The drain plug is on the black transmission pan.
Fill with a funnel at the dipstick tube. You can remove the cap.
Even when you remove the drain plug, and all the fluid comes
out, there will still be a ~quart in the pan. This is because
the plug landing is raised up, and has a 1/4" collar that is also
raised up, for about .5" of rise, which means it all won't drain out:
NISSAN PROCEDURE:
Drain, Fill (4 qts), start car, idle in "P" 5 seconds, Brake; "R" 5 seconds, "D" 5 seconds, "P" turn it off.
Drain, Fill (4 qts) , start car, idle in "P" 5 seconds, Brake; R" 5 seconds, "D" 5 seconds, "P" turn it off.
Drain, New Plug Gasket, Fill, start car, level procedure, DONE!
This is why is costs $288+ at a dealer. This is so you will have > 75% fresh fluid.
I just fill it cold until fluid comes out the level hole, and I let it go till it
drips. Then I put the level plug back in and I am done. A half pint over
won't hurt anything. Walmart has the 4-quart Castrol CVT jugs for $24.
IF you have the miles, then do the pan drop and filter change after the second fill,
so your 3rd fill will be with a new filter. You will be putting about 5-quarts in
with the pan drop. If you do the NISSAN procedure without a pan drop, you will
need three jugs of CVT fluid. IF you do the pan drop on the 3rd fill, you need an
extra quart.
Svtrit
If you are doing 1200 miles a week,changing the fluid every 50k instead of 30k would be fine. Highway miles are easy on a car, especially when using cruise control. My first Rogue was a pharmaceutical rep car and had 103k miles in 2 years. Easy miles for sure.
PowerslavePA
Svtrit wrote:
Mon Jul 10, 2023 6:42 pm
IF you're referring to me, I also have an aux cooler on after the radiator.
I cam safely change it very 50,000 miles. However, the x-fer case and
diff I will do every 30-35K. There is only .6 pints in the x-fer case, and
that's just not enough. The diff doesn't even take a quart, also not
enough. SO, they need changed more often, using AWD or not because
it's all still spinning.
Svtrit
Isn’t the transfer case part of the transmission in this generation Rogue? That’s what the dealer told me when the did my 2016 back when I had it.
I never found a drain or fill plug where the driveshaft goes into the transmission.
VStar650CL
Technical Expert
It's attached to the transmission but has separate fluid.
Svtrit
Does it also use CVT fluid?
VStar650CL
Technical Expert
No, I think all the gen2's use GL-5 80W90 for both the transfer and diff.
C-ya
Car: 2011 Nissan Rogue SV AWD
Svtrit wrote:
Fri Jul 21, 2023 7:46 am
Short and sweet video showing the xfer case and rear diff.
KoiMaxx
Car: 2017 Rogue SL AWD
@Svtrit and remember to get one of those fluid transfer pumps if you don't have one yet to change the oil in the transfer case or diff.
Svtrit
Thanks for the video and the comment on the pump. As an avid Jeeper, I have a pump for my transmission and transfer case maintenance in the Jeep.
I’ll add this to my next oil change at 30k miles, as I plan on doing the transmission then.
C-ya
Remember to always loosen the fill port before removing the drain port!
rajesh1136
Im in middle of buying CVT oil. Replacing my Transmission. How much is required for the initial fill ? as i wont do drain and fill ? 2016 Rogue
@VStar650CL
VStar650CL
Technical Expert
Dry capacity is nominally 8.38 quarts.
rajesh1136
VStar650CL wrote:
Sun Oct 29, 2023 6:35 am
Thanks. To to be safe can i just do 8 quarts and then top it if required ?
I also saw this product in Amazon which has dip stick and it is compatible with rogue. In youtube i saw someone using the dipstick.
https://www.amazon.ca/gp/product/B08NWS8RSD
will it wok to measure?
VStar650CL
Technical Expert
Use the leveling plug. You can't screw around with the level on a CVT. Even half a quart over will eventually kill it, and a full quart over is a real fast death sentence. Once you get it right with the leveling plug, you can mark and calibrate an aftermarket stick.
rajesh1136
VStar650CL wrote:
Sun Jun 25, 2023 1:29 pm
I saw this level plug. not sure how to use it ? any instruction. i couldnt find any more info.
rajesh1136
I found you explaining this in another forum. Basically hiccup drain
VStar650CL
Technical Expert
Correct. The transmission needs to be warm and the car level, but there's no other big trick to it.
9TBMY3B98
Car: ???
Hi tedc,
I just read this post, because I will be changing the CVT fluid in 2018 Rogue Sport. The first thing that you suggest to do is: "Drive vehicle until engine oil temperature is at normal level on dash gauge." Why is it important, considering that in the service manual, it says that the CVT fluid temp should be: "104°F or less", which is basically the cold engine temperature in mid-summer?
Would you please clarify that? I am going to do it the first time myself and worry about the details too much.
Your input would be much appreciated.
VStar650CL
Technical Expert
Unless there's a leak or you're dropping the pan, the best way to DIY changes is to simply replace exactly what you take out. That should always be done cold, so the old fluid and new fluid are at about the same temperature and don't throw off the measurement.
9TBMY3B98
Car: ???
VStar650CL wrote:
Sat Jul 20, 2024 6:58 pm
Make sense. Thanks!
VStar650CL
Technical Expert
:dblthumb:
KoiMaxx
My Rogue was due changing the fluids in the engine, transmission, transfer case, and differential. Had a pair of ramps that I used for several years to do maintenance under the car, but I finally decided on getting a similar pair when it was on sale. I never realized how much easier I could work with all 4 corners up instead of just having the front or rear end up and having to swap out afterwards. So much room! :woot:
I still do the 2x drain and fill on the CVT following the modified FSM procedure. I seemed to be more quicker doing it now than the first time, but I guess that comes with the experience. Transmission and engine feels a lot smoother and zippier again with the new fluids in.
nabril
Car: 2015 Nissan Rogue SL
and this thread remains alive... It has very important information to be read and re-read.
I recently traded in my 15 Rogue for a 24 MachE, and so far I like the change. However, my wife's 2016 Rogue remains with us and well-kept, and so I can't erase this webpage's browser bookmark. I remain grateful and thankful to @casperfun, @Vstar650cl, and many other people that have helped us maintain our Rogue's in good shape.
I changed her transmission oil back at 42k miles in 2022 with a single fill thanks to this thread, and I would like to do it again now at 70k. I had to read and re-read the steps so as to get re-acquainted with them, but now I'm curious about dropping the pan, replacing that auxiliary filter, and the differential fluid or any other change that may be useful.
1. In dropping the pan, can the cover, the exposed area, and the screen be cleaned with Brake cleaner, for example? Is it worth cleaning the screen?
2. Getting to the auxiliary filter cover's 4 bolts looks extremely difficult and complicated. I own a few tools, but getting to those 4 requires creativity. I've seen a few videos on it, but none of them have a detailed explanation for getting to them. Is it "worth" the effort? I saw a post that mentions that it makes this a 3 hour job.
3. The car is a FWD, and I read in another post that fwd's use the same cvt fluid, or something like that; i don't remember the wording.
I continue to thank any help.
VStar650CL
Technical Expert
For FWD there's no transfer case or rear diff, so when you change the CVT fluid you're also changing the front diff fluid, it's all integrated. Intake cleaner is a better choice for cleaning the screen, Brakleen leaves a residue. Unless you find anything bigger than fine shavings on the pan magnets, leave the paper filter alone, it won't be clogged and isn't worth all the PITA.
nabril
VStar650CL wrote:
Tue Mar 11, 2025 8:15 am
For FWD there's no transmission case or rear diff, so when you change the CVT fluid you're also changing the front diff fluid, it's all integrated. Intake cleaner is a better choice for cleaning the screen, Brakleen leaves a residue. Unless you find anything bigger than fine shavings on the pan magnets, leave the paper filter alone, it won't be clogged and isn't worth all the PITA.
thanks again V, and good tip on using intake cleaner.
I am going to attempt a dual fill this time. Will 6.5 quarts be sufficient (I have 1/2 left over)? I'll use 3 and a bit for both fills. Or should I get a 7th just in case?
Amazon has the Nissan ns3 for $15+ per quart, which isn't bad, but Napa has the Eneos for $12... Hmmm
Return to “Rogue Forum”
