VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Tue Jun 15, 2021 6:07 am
The DRL circuit is pretty simple, there are no fancy diagnostics to worry about and both lamps are fed from a common wire and a common relay. The relay is all by it's lonesome directly behind the righthand headlight assembly. The violet wire into the relay is the "trigger" from the IPDM, interrupting it with a switch will allow you to kill the DRL's.
