Same tranny as the FWD Juke, yes. AWD was different.Nismodude21 wrote: ↑Thu Sep 30, 2021 7:16 pmAwesome is this the same process on the 2014 or so Juke? I read you have to pull the inner fender well off to get to it and use a pump to get the fluid back in basically?
Nissan recommends it every 10K, but for what's basically hypoid gear oil, that's very extreme. I'd say 50K is probably appropriate unless you're really hard on it.Nismodude21 wrote: ↑Thu Sep 30, 2021 7:18 pmAlso what is the suggested interval for changing this fluid? I’m at 50k and it feels long overdue
It's true that turbos are a little harder on the plugs, and it also depends which brand Nissan gave you. Densos are hotter but erode quicker, NGK's have harder electrodes and last longer but often won't start a flooded engine. Replacement choice is up to you, Nissan uses both brands in various engines. Neither one will be shot at 30K, but if your originals are Densos then 60K is probably appropriate. NGK's will go 100K in almost anything, turbo-or-not. If you really don't want to replace them again anytime soon, NGK's new ruthenium plugs are supposed to have double the lifespan of iridiums with no decrease in performance. We haven't seen enough of them yet to evaluate the claims, but I also haven't heard anything bad or contradictory.Nismodude21 wrote: ↑Thu Sep 30, 2021 7:18 pmI’m also on the same spark plugs at 50k I had one dealer tell me they were 100k spark plugs and another tell me change them at 30k because it’s a turbo car
