Jdr2916 »
https://forums.nicoclub.com/jdr2916-u313379.html
Thu Sep 19, 2024 10:05 pm
Hi all,
So my Nissan Rogue 2017 SL came up with the occasional judder, typically when driving more than 30 mins or so. Other than that car still drives good and after having a mechanic look at it, it has the p17fO code stored, with no check engine light. I believe he said it also has a P0841 code.
Car has 32k miles, Nissan won't help to cover any costs and I assume I will require a CVT replacement. Question is, should I drain and fill the transmission fluid and will doing so, possibly have any effect and perhaps it will last a bit longer?
Can the judders be caused by dirty or even low fluid?
Just don't want to waste a few hundred bucks if it won't help. Asked Nissan and they said sure give it a try and a transmission shop said don't bother. Any help would be appreciated.
