2016 Rogue Collision Avoidance Light and Climate control
hazmat1121
Car: 2008 Pathfinder LE
My 2016 rogue has the collision avoidance warning light on and the climate control panel is totally off. There is also a single audible tone when I start the car. This happened out of nowhere as I drove the car earlier today without any issues. I am thinking fuse but I am not sure. Any help would be appreciated.
V6er
Car: 2014 Nissan Rogue T32 SL
2023 Nissan Rogue T33 SL
did you read owners manual? what course of action does it suggest?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
Fuse #20 in the cabin fusebox supplies the brake pedal position switch for the ADAS in addition to the Front Air Control. That's your most likely culprit.
hazmat1121
Weirdest thing. I started the car today and no issues at all. Do you still think it could be the fuse?
V6er
probably - camera/sensors are dirty or their wiring has cracks >> gets wet etc
hazmat1121
Camera/sensor was an initial thought of mine as will but I'm not sure what the sensor for collision avoidance system has to do with the climate control panel. That's what's really throwing me through a loop.
VStar650CL
Technical Expert
hazmat1121 wrote:
Tue Sep 10, 2024 9:38 am
It doesn't. Take a look at the SMJ and adjacent connectors in the kick panels on both sides, make sure you don't have a water intrusion issue.
hazmat1121
SMJ=super multiple junction? I am not familiar with the term so I searched online.
I'll check for water intrusion but it's been dry for a while. Doesn't rule it out, just makes it less likely.
VStar650CL
Technical Expert
hazmat1121 wrote:
Tue Sep 10, 2024 12:12 pm
Correct. There are also a bunch of smaller connectors in the same area, especially on the driver's side. There was actually a recall for the one closest to the floorboard, intrusion is pretty common in that area even in vehicles with no sunroof:
https://static.nhtsa.gov/odi/rcl/2022/R ... 4-7750.pdf
V6er
VStar650CL wrote:
Tue Sep 10, 2024 2:14 pm
there is no like button on this forum - but thanks !!!!!! :D
is this the same issue/solution as with "can connectors failing" (read somewhere online that that is typical and people just solder wires together, deleting connectors, but wasn't been able to find proper list of those problematic can connectors).
hazmat1121
Thanks! I will need to check that area out and also see if the car has been in for the recall inspection. The issue has not happened again since the other day but it is clearly something I need to diagnose as to why it happened the first time. More to come...
VStar650CL
Technical Expert
There's a complete FSM here for your '16. The harness layouts will be here:
https://www.nicoclub.com/service-manual ... 6%2FPG.pdf
Connector pinouts are found in individual wiring diagrams in the individual sections.
Return to “Rogue Forum”
