VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Sun Dec 21, 2025 4:48 pm
Yep, an "S" trim will definitely have Manual. The following all assumes the fuses are good and you've already performed the test I described earlier to exculpate the blower relay. Pop the connector on the VBC (resistor) and use a jumper wire to temporarily ground the fat Green wire. It will spark, so don't startle yourself. Once it's grounded, the blower should run at top speed. If it doesn't, remove the glove box and check for the same voltage at the Red blower wire as you saw at the fuses. If so, the new blower motor is bad, if not, there's an open in the wiring between the fusebox and the blower. If the blower does run when you jump Green, the motor is fine and the problem is in the VBC, the wiring, or the control head. To determine which, first use a thick paper clip to jump the Green terminal to Violet. Grip the clip with a pliers, it may get hot. If that doesn't also make the blower run full speed, there's a problem in the ground wiring. If it does run, next put a voltmeter between the Pink wire and ground and turn the blower speed dial. The voltage should rise and fall as you turn the dial back and forth. If it does, the control head is good and the VBC is either bad or the wrong part. If the voltage doesn't move, either the control head is bad or you have an open in the Pink wire.
