2016 Q50 RS - Trailer?
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
dbaxRonin
Car: 2016 Infiniti Q50 Red Sport 400
2010 Infiniti G37x AWD Coupe (Traded in)
2001 Infiniti i30L (Traded in)
Really want to get a snowmobile this year, but need to be able to tow it to the trailheads. I see that there are Class 1 hitches available for the Q50, and the tow rating is around 2000lbs with 200lb at the tongue. 2 sleds and a trailer would likely come in around 2k. Anyone have any experience doing this? More than likely it will just be 1 sled for now, but the other half might want one eventually too. Appreciate any advice on the matter!
audtatious
There should be a towing guide that was included with the vehicle. If you can't find it then searching google for "2016 infiniti q50 towing .pdf" should give you proper results.
Otherwise, I'm not much help....
Return to “Infiniti Q50 / Q60 Forum”
