sumac0401 »
https://forums.nicoclub.com/sumac0401-u294375.html
Fri Sep 30, 2022 7:32 am
I have the front set to the softest setting and the rear set to middle. Handling was slightly improved with older tires. Recently I put in the Power Stop BBK (same as Akebono). I wanted to keep my OEM 19 inch wheels so had to put in longer wheel studs and a slip on hub-centric 15mm wheel spacers on both front and back. I also replace new tires. Now the handling has improved a bit more. However, not sure if it's because of new tires and slightly wider track with the wheel spacers.
