2015 QX60 code p0101
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
ev713341
Car: 2015 Infiniti QX60
Engine does not hesitate, but have the maf code. Do I replace or clean?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
There's a bulletin about it, ITB19-027:
https://static.nhtsa.gov/odi/tsbs/2019/ ... 6-0001.pdf
Basically, if your ECM part number suffix is any of the following on a '15, you take it to the dealer and get the ECM reflashed:
9NE4A, 9NE5A, 9NE6A, 9NE7A, 9NE8A, 9NE9A
9NE4B, 9NE5B, 9NE6B, 9NE7B, 9NE8B, 9NE9B
9NE4C, 9NE5C, 9NE6C, 9NE7C, 9NE8C, 9NE9C
9NE4D, 9NE5D, 9NE6D, 9NE7D, 9NE8D, 9NE9D
9NE4E, 9NE5E, 9NE6E, 9NE7E, 9NE8E, 9NE9E
VStar650CL
Technical Expert
FYI, P0101 isn't a MAF code per se, it's an induction performance code. It means something isn't making sense on the induction side of the engine, but the ECM can't figure out what.
Return to “Infiniti Q50 / Q60 Forum”
