2014 Rogue windershield washer not working
GerGa
Car: 2014 Nissan Rogue
Hi guys, I have a 2014 Rogue and the windshield washer doesn't spray. It is full of washer fluid.
I will be driving in a bit of snowy weather in the coming days and don't have time to get it fixed under warantee for now. Is there anything I should look at to fix it? Anything common that causes this?
Thanks
bigbrotherbear
Car: 2008 Nissan Rogue
How cold is it where you live? If it's too cold, the washer fluid in the lines could be frozen. Are the nozzles clogged? Try poking the nozzle heads with a fine needle to see if that's your issue. There could always be the possibility that your pump could be broken. :(
Maximus099
Car: 2014 Nissan Rogue SV AWD
Like bigbrotherbear said try cleaning the nozzles where maybe ice has formed and add winterized washer fluid if it gets cold in your region. Does the rear one work? Do you hear the pump working? Park it indoor for a while to unfreeze the nozzles if thats the issue.
Ferrisfan
Car: 2014 Rogue SL FWD w/ Premium Package
Quick and easy check is the fuse. If it tried to pump semi-frozen slush then it might have blown a fuse working against that pressure.
Return to “Rogue Forum”
