This is not a good idea, you run the risk of melting/damaging the fog lamp housing, connectors and/or wiring due to the increased heat. If they get damaged, you could be denied warranty coverage and have to pay to replace the fog lamp and/or wiring.AnthemGems wrote:So Far, So Good....No Problems w/ 80 watt bulbs
I agree. By using a higher watt you're risking melting the assembly. If this happens warranty won't cover it and headlight assemblies are not cheap. You may not have had any issues yet, but in my opinion it's not worth it chancing that kind of issue. If the warranty doesn't matter to you then by all means go for what you want. Just know what you're looking at if a problem does arise.sprocket wrote:This is not a good idea, you run the risk of melting/damaging the fog lamp housing, connectors and/or wiring due to the increased heat. If they get damaged, you could be denied warranty coverage and have to pay to replace the fog lamp and/or wiring.AnthemGems wrote:So Far, So Good....No Problems w/ 80 watt bulbs
Stick with the specified wattage bulbs only.
