Proeteus wrote:It is the redesigned rogue not the select . Thequestion is for both 2014 and the 2015. As far as what aids I will list them below.
Nissan connect with ithNavigation System(7 inch monitor with SD card port)
Blind Spot Monitor
Lane Departure Warning
Rear Parking Aid
Power Liftgate Litigate.
I am wondering if any of them can be installed by dealer..
i'll be honest with you, a dealership is actually 2 businesses. 1 is the dealership, and the other is the service bay = aka = mechanic shop.
a mechanic shop will install pretty much anything you ask, as long as its legal. so to answer your question: YES they will install pretty much all of those things; but at what cost?
you can turn a sv into an SL, but at what cost? its going to cost you more than if you bought the SL... why? shop time. PLUS now you are buying those parts & supplies from a dealership(business); basically now you added a middleman to the ordeal.
