Rogue One »
https://forums.nicoclub.com/rogue-one-u185971.html
Wed Sep 20, 2017 6:35 am
Welcome to NICO!
I'm not sure what you mean by "Transmission won't pull properly." How long has it been between the repair and your creating this post? How far have you driven the vehicle since the repair was made? Is the SES light or any other warning light on? The CVT requires at minimum to be checked every 30k miles (Nissan recommends 15k intervals). Has this been done?
I believe that you can unplug the negative cable on the battery for around 15 - 20 minutes, which should reset the fail safe mode back to normal.
If the problem persists after that then there's something else going on that will necessitate a return trip to the repair shop for a proper inspection and diagnoses.
