VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Thu Jan 20, 2022 8:29 am
I'm not sure if it's accessible, there are two unlabeled relays on the IPDM layout and it might be one of them, or it might be internal to the IPDM. One of the Juke guys here might know the answer to that. Assuming fuse 43 is good, if you look on EC-115, the ECM Relay feeds two wires out of the IPDM, pins 35~36. You can locate them in the diagram on PG-33. Put a bulb-type test lamp between those wires and ground with the key on, the lamp should light. If it does, then the relay isn't your problem.
