Rockhound2.0 wrote:I had a bit of a breakthrough tonight. After spending about 30 minutes driving at night this evening, blinding oncoming drivers and illuminating treetops, I decided once and for all to get to the bottom of this. I poked around under the hood and found what I believed to be an adjustment screw, but I didn't have enough space to actually adjust it. Then, a few futile web searches for a '14 Rogue service manual led me down a different path...
A friend of ours recently purchased a new Honda Pilot, and she too said that her headlights were aimed at an upward angle and that she was frequently being flashed by oncoming cars' brights. I began to search Pilot forums and lo and behold, found that there were several threads on the same topic. What I found was a screenshot of the Pilot service manual, indicating the leveling procedure using a phillips screwdriver (see Figure 1).
Figure 1 - Honda Pilot service manual headlight adjustment instructions:
Looking at our Rogue's headlight assembly, I recognized the vertical adjustment screw that I had already tried (unsuccessfully) to adjust (circled below in Figure 2). If I recall correctly, the screw needs to be turned counterclockwise to adjust the vertical aim downward. It would seem that our Rogue's headlights came adjusted near the top of the vertical travel - a safety issue for the driver as well as oncoming motorists.
In Figure 2, I'm at a bit of an angle, so I drew in some lines to indicate direction. If you insert a phillips screwdriver into the hole with what appear to be gear cogs, the notches on the screwdriver catch the cogs and turn the screw. Note that there is also a horizontal adjustment screw on the headlight housing, and it is found on the outermost portion of the rear of the headlight and has a plastic cap over it.
Figure 2 - 2014 Rogue headlight housing, pictured from above
Lastly, I pulled our Rogue out onto the driveway, approximately 20' from the garage door. I placed some tape at an acceptable level and proceeded to turn the adjustment screws until each headlight was properly aimed. You can see how high the unadjusted driver's side was aimed in this picture.
Figure 3 - 2014 Rogue headlight pattern during aim adjustment
It's a bit puzzling that a vehicle can be sold to the public with the headlights so improperly aimed. Either the adjustment isn't being done properly during assembly, or it's the result of a (failed) pre-sale checklist at the dealership. Browsing the 'net, it would appear that our Rogue is not alone in this regard.
I wouldn't blame anyone for wanting their dealership to make this adjustment, but thought I'd share for those of you who are eager to properly aim their headlights.
