VStar650CL »
https://forums.nicoclub.com/vstar650cl-u299034.html
Tue Jul 23, 2024 12:39 pm
That's basically a short circuit, so it should be telling the HVAC that the evap is super hot. None of the HVAC's I've ever seen error-check the sensors, but I won't say that's impossible. Calsonic doesn't give us flowcharts, and the Quest has always been a redheaded stepchild with oddball hardware. You can check it by sticking a 2.2K resistor in place of the sensor and see if the voltage on the data wire matches the chart. If it does and the compressor is off because of a software safety, the compressor should start. If the voltage doesn't match then you have a wiring problem in addition to a shorted sensor.
VStar650CL on Tue Jul 23, 2024 12:40 pm, edited 1 time in total.
