Finally swapped it, got a pair of 6000ks. The color temperature is definitely better than the stock 4300k to my OCD. one of these days I'll figure out a way to post pics.NJGuy wrote:The stock HID bulbs are probably right around 4300K.
If you picked the white LEDs, I would guess that the color temp is 5000K. If you are that OCD I would double check with the vendors you purchased them from.
Litesaber5 wrote:Hi all. I know this thread is somewhat old but i have run into a problem on my 2008 ex35.
I installed new halogens on both sides and when i turned the lights on they did turn orn but almost no light was being cast in front of the car. No usable light that is. The brights work just fine but the low beams basicly are useless. I reinstalled the old bulb to see if it was the bulb but the same thing happened. No usuable light down range.
Is there an adjustment screw or something simmilar that i can turn or did i fk up the head lights.
Any help would be great.
Thanks
So i cant seem to find where that adj screw is. The manual is no help. Al it says is to bring the car inAWGD8 wrote:Litesaber5 wrote:Hi all. I know this thread is somewhat old but i have run into a problem on my 2008 ex35.
Thanks
I always recommend 5000 kelvin or lower if you want longer beam reach. Yes, there is a headlight adjustment for both side under the hood and you only need s longer thinner screw driver to adjust it.
Driver side beam should be lower than passenger side when setting up headight 25 feet facing from the wall.
