Looking for any experiences around the 2011-2013 QX56 TIming Chain Issue Recall on these cars. This issue popped up on me and being told out of campaign date. This is clearly a manufacturing defect. Car was in the shop getting one of the two catalytic converters replaced (also an apparent defect)
Looking for any guidance on fixing this issue, and any long term effects or concerns with the engine overall. My understanding is this is due to lack of proper lubrication over time causing the timing chains to stretch. Pointing to fault oil jets or oil pump. Not sure.
If that is true what other concerns would there be to the overall engine over time. Fixing this might just be temporary but overall impact could seriously diminish the life of the engine.
TSB has a procedure to check a hole in the block. If oil jet hole exceeds 3mm then instructions are to order a new long engine (long block).
I can't believe Infiniti is not fixing this, as it's a significant safety concern driving down the highway and have your timing chain fail.
Any experience or thoughts on this would be appreciated. I searched the forum and didn't find much. Internet has plenty to say about it.
