Boostn »
https://forums.nicoclub.com/boostn-u1717.html
Fri Feb 21, 2003 3:12 pm
The CA18ET has potential, but not as much as the CA18DET. The ET has weaker rods and pistons, plus a low flow head. It should probably top out around 300hp.
The CA18DET is a straight swap into the S12. It came stock in the 1988 200SX in Australia and Japan, so the motor mounts are identical to those found on the CA18DET. There's already two members with SR engines, which were both straight swaps.
