Nut Behind The Wheel »
https://forums.nicoclub.com/nut-behind-the-wheel-u293320.html
Sat Nov 30, 2019 7:29 pm
Over the last few days I have removed the passenger seat, lifted the carpet, removed the styrofoam pieces underneath, sucked up a lot of water and dried it all (man I don't want to go through that again... ). Now I am focused on resolving the actual leak. I have removed the front passenger side tire/wheel and the wheel well plastic cover. This revealed the drain outlet. This has pretty much been trial & error as I have yet to find any detailed documentation on this nor anyone else that has experienced this same issue on a Versa (although sun roof drain issues seem to be a common vehicle problem). I attempted to clean the tube using a .105" trimming line (weed trimmer line) from the top & bottom however I am totally stopped about 3"-4" into the lower drain tube. I did get some dirt & water out of the lower drain but going beyond that seems to be not happening. Versa Forum friends, having some insight (pictures, good diagrams, actual knowledge) as to what is within the frame would be most help. Thanks
