NewEX35Dude »
https://forums.nicoclub.com/newex35dude-u307979.html
Sun Aug 06, 2023 3:55 pm
Hello all. Just wanted to provide an update on the speedometer issue. I’ve replaced both front wheel hubs/bearing assemblies and both front ABS sensors. I think the drivers side is also a wheel speed sensor. I’m not clear on that. Anyway, the speedometer works okay most of the time but the needle doesn’t go to zero, it settles at about 5 mph when stopped. I haven’t taken the time to remove the negative battery terminal to cycle power to the ECU.
