amc49 »
https://forums.nicoclub.com/amc49-u275146.html
Wed Sep 19, 2018 1:15 pm
Shifter cable needs adjusting, or shifter assembly itself getting loose and needs rebuilding to tighten it up. Can't say exactly on console but not hard, you simply look for the fasteners.
The shifter ignition interlock there is intended to stop unsupervised children from getting the cars into gear. Once console is off you can generally figure out what linkage or solenoid works the interlock to deactivate or remove it to never have a problem there again, the car will then be like all old school ones are. Once I have a need there or am under console for other things I disable that interlock on every car I have. Of course, don't do it if you have children running around.
