2007 Versa - Engine cable goes nowhere!?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
billybala
Car: Versa
Hi all
Just installed the Takeda SRI in my Versa.. sounds good!
BUT = when I was taking out the stock airbox, I noticed that one of the cables coming out from the engine below the airbox was not connected to anything? It seems it was like this stock, There are cable ties which tie parts of this cable to the stock airbox. It seems very unusual
See pictures here -
P.S. Do I need to tie down the MAF sensor so the cable doesn't dangle? In the stock intake it was tied down, but with the Takeda I'm not sure where to tie it down.
AJVersa
Car: 2009 Nissan Versa S Hatchback
That hose (cable :confused: ) is the vent for your trans. Keep it up high. I hunge mine on the side of the master cylinder with a ty-wrap.
I have the DC Sport CAI, there was no problem with the MAF cable. When you bolt your MAF in place. Make sure the wiring doesn't make contact with anything that will damage it.
Return to “Versa Technical Discussions”
