2007 QUEST transmission fluid drain?
A forum for the Nissan Quest... minivan lovers unite!
merrittr
Car: 2007 Nissan Quest
I have a 2007 quest I was wanting to drain the t fluid , it does not have a pan under the van (it is sort of angled at the front. there is a HEX head bolt near by is that the drain plug?
pictures welcome
Take a pic of what you have, should be pretty obvious.
Also, check the FSM at nissanservicemanual.com, that'll show you exactly where the trans drain is.
Welcome aboard!
merrittr
ha perfect that link to the SM did the trick!
Return to “Quest Forum”
