Kylo_Rec »
https://forums.nicoclub.com/kylo-rec-u275416.html
Thu Aug 17, 2017 10:58 am
Hey everyone,
So after finding time to do the job, I did it. I changed the spark plugs and even moved the coil from Cylinder 1 to another one, to see if the issue would change.
After finishing the job yesterday, I took the car for a drive just to see if the rough idling is gone, but after a bit of driving, it came back. It didn't seem as bad as it was before, but its still obvious. The times you can really feel it are when you're stopped. Besides that, the car runs great.
So I'm wondering, since I changed the spark plugs, could it actually be the coil that's the issue? the check engine light came on again, blinking and then on completely.
