2005 nissan sentra
joseek991710
Car: 98" EK9
Does any one know the fireing order on a 2005 Nissan Sentra?
nissantech06
Car: 2007 Nissan Sentra S 2.0
joseek991710 wrote:Does any one know the fireing order on a 2005 Nissan Sentra?
All 4 cylinder Nissans use the same firing order; which I can't remember off-hand
joseek991710
Car: 98" EK9
THANKS BROTHA. STILL CAN'T FIND THE FIREING ORDER.
nissantech06
joseek991710 wrote:THANKS BROTHA. STILL CAN'T FIND THE FIREING ORDER.
If you wait until Saturday when I work next I'll look it up in the service manual.
joseek991710
Car: 98" EK9
What I'm really trying to do is remove the head and set it on TDC. Is it hard to remove the timing chain? Thanks for your help.
nissantech06
joseek991710 wrote:What I'm really trying to do is remove the head and set it on TDC. Is it hard to remove the timing chain? Thanks for your help.
1.8 or 2.5? Usually we just set the #1 piston (closest to the chain) to TDC.
joseek991710
Car: 98" EK9
All right thanks for the Info. Would you happen to know how to remove the timing chain? I appreciate your help...
nissantech06
joseek991710 wrote:All right thanks for the Info. Would you happen to know how to remove the timing chain? I appreciate your help...
You have to remove tension off of it to get it removed from the cam gears...the best way is to work it off of the guides and remove the tensioner.
joseek991710
Car: 98" EK9
is there any timing points or markings on the gears that you know of? Thanks.
nissantech06
joseek991710 wrote:is there any timing points or markings on the gears that you know of? Thanks.
I always mark it with a light mark of paint, but you can see on the chain and all three gears there are marks to line up. It's really easy to tell.
joseek991710
Car: 98" EK9
i only seen one timing mark on one of the cams. Is there also one on the chain? Thanks for your help.
nissantech06
joseek991710 wrote:i only seen one timing mark on one of the cams. Is there also one on the chain? Thanks for your help.
If it's the OEM chain, yes, it should be marked. I just did a head gasket on a QR25 and they were all clearly marked.
joseek991710
Car: 98" EK9
Thanks for your help i'll let you know how it goes tomorrow.
nissantech06
joseek991710 wrote:Thanks for your help i'll let you know how it goes tomorrow.
Did you get the timing chain all figured out?
nissanrocks
Nissantech 06, you just did a head gasket? I didn't thing apprentice mechanics got such work?
VMPhil
Car: 2007 Volkswagen GTI
http://nissansource.com/doug/S...d.pdf
since no one has answered it yet, the firing order is 1-3-4-2
