Postby Django89 » Thu Aug 20, 2020 8:06 am
when i was driving my g. It all of a sudden shut off and would not restart. I thought it was my relay for the ecm cuz it was buzzing swapped for another. Started the car. Shut it off and then would not restart. I have no ses light on the dash when key is in on postion and not running and cooling fans stay on high all the time. Fuel pump is acting funny. I thought it was the ipdm that got wet. Which it has before but cleaned the drain holes. took it out dissasembled it dried it. The fuel pump before taking the ipdm apart didnt work. After i dried the ipdm it works now but makes funny noises.and intermittimg pumps fuel. Ecm relay has power to two prongs whem checked with a test light. Anyone have a pinout of the ecm connector so i can check there for power and any advice. I do have a ses light befoee this for cat Efficiency and a manual trans switch switch. Any advice is much apprectiated
