2005 g35 coupe signal light failure
jcrowder
Car: 2005 G35 coupe
I had an issue with my trunk release and thought it might be a fuse (found a broken wire)
In the process I removed and replaced some fuses.
Now my clock doesn't work,signals lights work but dash indicator does not and my trip odometer resets everytime I start the car.
Any ideas?
Q451990
:welcome: to NICO!
I would certainly check to make sure you put all of your fuses back in the correct slots. If it's like my G, there are plenty of open slots, so if you're off by one, you could end up putting a fuse in an empty slot and leaving one that needs it open...
Heath
jcrowder
Car: 2005 G35 coupe
No luck. has anyone ever had this problem? Signal lights still flash just no dash indicators and clock is stuck. Can't reset the time.
SteveTheTech
Car: 15 Nissan Sentra SR
12 Infiniti G37x Coupe
-Formerly-
05 Mazda 6 L3 Sport
95 Infiniti J30
94 Nissan D22
I've seen a similar issue when the fuse directly across from the puller is improperly installed or open.
