Well it sounds like you have quite a bit of research to do first before even thinking about this swap. For starters, the VQ35 is a very common swap done to the B15 chassis, and is supported by swap kits and even bolt on parts that work with this particular setup, so swapping a 3.0L would be an unnecessary headache. Not many have been done (only a couple to my knowledge), and the 3.5 swap is becoming a very easy swap in the last year or so.megatron20 wrote:I am going to motor swap my 2.5 with a 00 maxima 3.0 engine. I have only seen 5spd maximas. i was wondering if a 6spd transmission from the spec-v would work and if the wiring harness would work from the maxima. If anyone could help or has done before and has pointers I would appreciated.
