2003 Pathfinder R50 OEM crank position sensor
Micallen
Car: 2003 Nissan Pathfinder SE 4x4 V6
Is it 23731-AL606??
04pathse
Car: 2004 Nissan Pathfinder SE
2008.5 Mazda Mazdaspeed 3
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
NissanPartsDeal uses the same dbase and drawings as the Nissan EPC system. So if that's what it calls for, it should be right. To be certain, plug in your VIN instead of using MY. The dbase will pull up the same built-with part number as EPC would give you.
Micallen
Thank you guys. Ordering now. Tired of getting 6mos to 1 year out of generic ones.
Micallen
Well, NissanPartsDeal.com just cancelled my order. Your order has been voided because of the following reason(s): The ordered part(s) have been discontinued (no longer available).
This was the only place I could find to order OEM. Anyone else know where I can get OEM?
Micallen
I found one on eBay. Supposed to be new and OEM. We will see.
VStar650CL
Technical Expert
Lots of the stuff on eBay and Amazon is "gray market" (i.e, genuine parts, but made for JDM or some other offshore market). However, it's rarely counterfeit if it's in Nissan packaging. Vendors know that can be Federal trouble if they're caught.
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Micallen wrote:
Tue May 24, 2022 3:32 pm
If you ordered the discontinued part number 23731-AL606, then the cancellation notice makes sense. Nissan Parts Deal shows that part number 23731-AL60C replaced it and multiple parts replaced the C version. Nissan USA shows part numbers 23731-AL60D and 23731-AL60E both replaced the C version (also discontinued), both are active parts, and both show fitting the '03 Pathfinder. Nissan Parts Deal cannot verify fitment of either the D or E version on the '03 Pathfinder. You should call a dealership parts department to confirm, with your VIN, which one is right for your '03.
mdmellott
I just checked Nissan Parts Deal again. It now shows D and E fit the '03 and that D replaced the original number. Timing here with these posts and NPD updates may be coincidental but I can't help but wonder if we are getting our information from Nissan Parts Deal or are they getting the information from NICOclub. ;)
