Sentientbydesign wrote:I have illuminas on my I30 (4th gen). The lower numbers represent a harder ride. So 1 would be stiffest, 5 softest.
Eibach makes two lines of springs for our cars. The prokit is rated at somewhere around 1.5-2". You get increased handling and a lower center of gravity (less body roll). They also have the sportskit. If I remember correctly the sportskit drops your car around 3.5 inches. It's significantly stiffer.
On my I30 I have the Prokit with tokico illuminas up front and the HPs in the rear. I got about 2.25-2.5" drop.
Hmm...I think you were misinformed....5 is, indeed, the stiffest. Have you tried switching the settings from 1 to 5? You will definitely notice the difference in stiffness between the two. Here's a quote I got from a webiste:
"TOKICO Illumina adjustable series offers some of the highest shock absorber technology currently available in the aftermarket.Tokico Illumina gas shock's ease of adjustment and change in vehicle response is second to none. The Tokico Illumina uses a specially calibrated orifice bypass system which allows simultaneous adjustment of both compression and rebound. Each adjustment "clicks" so you always know your shock settings. The adjustment range of Tokico Illumina is one of the widest available, with 5 separate positions. Position 1 is the softest, or lowest damping force, while position 5 is the stiffest. Whether you are looking for ride or superb handling,Tokico Illumina is the answer."
Also, eibachs are about a 1.3" drop in the front and a 1" drop in the rear....i haven't heard of any 3.5" drop availiable to us besides slamming your coilovers...and the eibach sport kit isn't available for maximas...
