Thanks Audtatious:
Guess I could take a voltage reading then pull the fuse to see if there is any difference in the reading, would you know where the radio fuse is located? What size is it 15 AMP, 20 AMP? Crazy thought, but, what's the chance of installing a toggle switch in the audio circuit so it can be shut off when not in use? Mount the switch under the dashboard somewhere, is that over the top? Too complicated?
Telcoman:
Yes, I am aware of all your points, and they are most certainly valid, what I failed to mention is right after I dropped $1,600 + for a major service in September 2010 (and $760 in October) a week later I was hit in the third round of layoffs from FDOT, have not been able to secure a meaningful (financially) position since, having to take yet another hit for work that was supposed to have been done really steams me. You did see where I put in a new battery (and not a cheap one), so that problem is checked off, the alternator is pushing 14.56 AMPs so that eliminates that, to me both the battery and the alternator are not part of the problem, whatever is drawing amps with the ignition off is the problem, how to determine what seems insurmountable, unless of course I take it to the dealer or some one that can perform a diagnostic profile, which I can not afford to do right now. I must apologize for how this seems to be turning in to a sob story. I do appreciate your input.
PS: Every system in the vehicle performs perfectly, there are no problems with anything
, AC, radio, CD etc. etc.
