you are so very wrong.sijoko wrote:as a rule if you double the atmospheric pressure going into an engine you will approximately double the horsepower. That means if you take a 340 hp engine and run 14.7 psi of boost with a properly sized supercharger you can expect 680 hp minus the power to run the supercharger.
you could take a Garrett GT2860 turbocharger (this turbo flows a maximum amount of air to make 360hp), and set it up on your 4.5L. set up the wastegate to 14.7psi. you will certainly NOT make 600hp. the turbo isn't capable of flowing more than 360hp worth of air.
i have no idea how much pressure the turbo make when it flows 360hp, but it is much higher than 14.7psi (maybe 30psi?), it certainly doesnt make 600hp there either.
the same logic applies for a supercharger. there is a certain speed you can accellerate a supercharger to where it no longer flows more air than it did at a lower RPM, this is beyond its efficiancy point. this factor allows you to determine the maximum amount of air the compressor will be able to flow. most manufacturers of turbos and superchargers will tell you the max amount of power it can make.
the amount of boost pressure is not a factor. the amount of air mass it flows at a given RPM within its efficiancy range is the only thing that will tell you how much power the blower can make.
by your logic, any turbo capable of compressing air to 14.7 psi could make an engine produce 600hp, as long as it made 300hp in its normally aspirated state.
air-mass = power (potential power)air-pressure = merely the compression needed to compress that air mass to a volume able to be forced into the engine.
