EdBwoyhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=f09b48f06fc51dec48cf0f7f8408d8192002+ Q45. Major Fuses, relays and modules... and their locationsWed Jan 16, 2019 1:06 am
Postby
EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.htmlWed Jan 16, 2019 1:06 am
This info was based on a 2002 Q45, US Model. I cannot confirm what differences, if any, the 2005+ have. Maybe someone with an 05 or 06 can compare pictures of the fuse covers and let us know where the differences are.
I suppose for members in other markets everything is flipped from left to right?
First, these are locations of the components you are most likely going to deal with.
Postby
EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.htmlWed Jan 16, 2019 1:08 am
In the left interior we have Junction Box 1. The most common thing that comes to mind when we think "fusebox". It is located in the left kick panel, beside the parking brake pedal.
The accessory relay is located on the back side of this unit.
schematic layout
Postby
EdBwoy »
https://forums.nicoclub.com/edbwoy-u213758.htmlWed Jan 16, 2019 1:09 am
In the right interior we have Junction Box 2. It is not often that we remember this when we talk about a "fusebox", plus it doesn't have an easy access door. It is located in the right kick panel, and you access it by removing that interior trim piece.
You have to remove it and flip it to access the fuel pump, ECU and blower relay.
Layout
Location
this is the trim piece removed, no labels visible on mine
I might have missed it, but it doesn't seem like these fuses are labelled anywhere, so here goes the result of my research
Car: Nissasn Y34 Gloria Ultima with a VQ30det same base car as a Y34 infiniti M45/M35 Nissan F50 Cima VIP with a VK45de same base car as a F50 Infiniti Q45
