2002 Frontier S/C boost gauge problems
moyea
Car: Paddle Shifted 92 240SX SR20DET, 02 Frontier S/C, 90 240sx ITA
I recently installed a boost gauge on my supercharged frontier. I wasn't too sure about where to tap into boost/vac source but I thought I had found one. The gauge read vac and boosted to about 5-6 psi on my way to work.
After work though, I couldn't get the damn thing to boost past 2-3psi and on top off that its off zero. Sounds like the gauge broke but I'm not convinced that's the case. Maybe the car got thrown into a safe mode of sorts (possible leak or such).
Any suggestions would be helpful.
tcowan
Car: 2002 nissan frontier supercharged 4x4
i have the same truck what gauge and pillar dd you go with
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Best place for tapping vacuum is after the throttle butterfly plate.
moyea
I need a visual, you got any pics of how you tapped for boost?
I went with the Lotek Inc. gauge pod (2pod pillar).
I also found that its got a bad knock sensor which is limiting my boost.
MY1PATH
Car: 1974 Datsun 260z
1989 Nissan Pathfinder
1993 Nissan Pathfinder
Bringing up the dead, What did the gauge read once you got everything fixed?
Is 6psi the stock boost for the vg33er?
I'll be adding this SC to a ~10:1 engine so I'd like to know if I need to turn it down or not. (6 should be safe)
I like to tee vacuum/boost gauges with the Fuel Pressure Regulator because it uses real time boost/vac feedback to vary the fuel pressure.
