jaxmax »
https://forums.nicoclub.com/jaxmax-u149402.html
Sat May 21, 2011 8:33 pm
Hey gents, Just replaced my radiator after it split a seam. My SE has 107,000 on it and is a manual, black of course. I couldnt find the coolant drains on the block so I put a hose in the upper radiator hose and put water thru till it ran clear on the lower hose. Did not remove thermostat. Haynes says to remove all drive belts when it doesnt appear necessary. Installed new radiator and filled. Ran engine with heat on high for 30 mins at idle, good normal operating temp but 0 heat, none. What the heck?
