2001 Q45t noise from airbox
Mrelcocko77
Car: 2001 Infiniti Q45t
2000 Nissan Maxima SE
1997 Infiniti Qx4
Guys, I need help diagnosing what's causing this noise. It doesn't sound good. The video explains it in detail.
Please help
Reason: Fix Link(s)
Q451990
:welcome: to NICO! I remember your video from facebook a couple of months ago. The closest thing it sounds like to me is when I put a pulley together in the wrong order once, but you don't have belts on. I think I'd at least get the water pump belt back on so that you can run it longer. Then use a mechanic's stethoscope to narrow it down.
Mrelcocko77
1997 Infiniti Qx4
I've used the stethoscope and still can't pinpoint the noise. I followed it all the way to the throttle body from the scoop sitting on top of the radiator.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
When did it start doing this, and what work has been done on the engine recently (your video mentioned spark plugs)?
On FGY33, you have 4 belts, but as Heath said, need at least the crank to water pump belt on so you don't overheat while troubleshooting.
I didn't hear you rev it....what happens when you vary RPM (don't go crazy), just change it and see if sound changes?
98_Q45
Idk if the issue has been fixed: but it sounds like what happened when I forgot to plug in the vacuum hose leading to the brake booster in my maxima. It’s definitely a vacuum leak sound...
I once had 2 vacuum leaks: an egr hose and the intake manifold.
