joshlobe »
https://forums.nicoclub.com/joshlobe-u306298.html
Sat Jun 11, 2022 8:21 pm
Newbie here. I have a 2001 pathfinder LE 4x4. It has an intermittent rough start issue. Sometimes she will fire right up. Sometimes she will crank for 10 seconds with nothing. Sometimes she will crank 3-4 seconds, then try to catch and sputter for a second, then die. Then try to start again, and she fires right up. I have found nothing to indicate any circumstances for replication. It might happen when cold, when hot, after driving for 2 hours, in the morning, at night... it's just extremely intermittent. Once she is started; she runs like a beast. No signs of rough idle, stalling, jumping rpm's, or anything like that. I can drive her for hours without any issues.
One more thing I noticed today; if I turn the air up to max AC, I will have more of a difficult time getting her started. She will still start, but very reluctantly.
She was taken in for service by my ex about two weeks ago; and had new fuel injectors, new throttle body, new plugs and coils, new air filter. But this problem has been ongoing for more than a year.
- I have replaced all (both) fuel pump relays under the hood as well as the fuse inside the cabin.
- When turning the key to "on", I can hear the fuel pump prime, but not every single time. Sometimes I turn to "on", hear it, attempt to start and get a rough start then die, turn it off then "on" again, don't hear pump, but she starts right up. Should I hear the pump prime every single time? Or only when it needs pressure?
- I have read about fuel pressure regulator. I have removed the vacuum line to the regulator and see no signs of wet gas or any smell of gas. I removed the fuel pressure regulator assembly and got gas spraying into my face, so I believe it is working fine.
I do not have the tools to test fuel pressure. I don't mind buying them, just not sure what I would need or how to test.
I also don't mind taking to a mechanic, but wanted to get an idea of what I could be dealing with here.
Any suggestions or input would be most appreciated.
