The A/C cut off last Monday and I assumed it needed another recharge (there's a leak in the A/C system, will fix it in the winter) until the next morning, I tried to drive to work and noticed the defrost wasn't working. Heat wasn't hardly working either. I was a few blocks from the freeway when I started seeing steam/smoke from the hood. Pulled over and saw leaking antifreeze, so I tried to make it back home and take the other car to work. Needless to say, I didn't make it home. The car was still driving but I must have lost too much antifreeze because I could feel it. I got the car towed home. Got around to taking a look under the hood and noticed this one metal pipe connected to a hose that looked like it runs to the A/C system (the pipe runs to the firewall and back out to the driver side) - this pipe is covered in antifreeze. I can't determine the location of the leak, unfortunately.
I have attached some pictures that hopefully show a clear location of this pipe. Does anyone know where this leak is coming from?
I appreciate the help. I have been helped so much by this forum in the past!
This is right between the radiator and the front of the engine on the passenger side.
