MattB »
https://forums.nicoclub.com/mattb-u6948.html
Sun Jun 19, 2011 3:31 pm
More details based on a test drive that may help:
Here are the conditions that produce the noise:
Accessories/AC on or off
Moving, any gear, around 2000RPM (not present above or below though slight indications of it at idle)
First 15-30 seconds of driving
The noise is a whine, not the scream of a bad belt. After the first 15-30 seconds of driving, the noise disappears and does not reappear. The pitch changes slightly as the revs pass through 2000 and to about 2100RPMs, almost like there's some kind of harmonic vibration. Other than this noise the car is in good shape. All fluids have been changed within the last 30K, no leaks, no rust, engine revs freely to redline and transmission shifts smoothly even at high RPMs. The vehicle recently had a 90K maintenance done and no problems were noted.
