jsta22 »
https://forums.nicoclub.com/jsta22-u193700.html
Mon Nov 14, 2011 6:19 pm
Hey, did you ever figure this out with O2 sensors? I am having a sluggishness problem as well.. New MAF but no ECU update yet.. But weird thing is, I read about sluggish O2's and went out and disconnected both my pre cat O2's that tell the ECU what A/F mixture to run, and the car runs a LOT stronger! Dont know if the O2's are the problem? or something else in the "closed loop" mode is causing this sluggishness, and simply disconnecting the O2's makes it run in "open Loop' mode.. Help is greatly appreciated!
