maxnix wrote:Might have fried the ECU. Best to charge the battery while disconnected from the car.
Don't scare the guy.
There is a high amp fuse on your positive battery cable, right next to the battery, it is likely blown.
Depending on how old your battery is, you should probably just replace it. A new battery can take a couple of discharges (although its not good for them) but an old battery will be killed by a single overnight discharge like yours.
Good luck and make sure to report back with the solution so that future seacrhers find this post and answer.
