Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Fri Jan 26, 2007 10:59 pm
Wow, I'm not sure. Usually when the reserve tank gets overfilled, it's because you're overheating. When you're overheating, the heater blows REALLY hot air. Unless the heater core is out, in which case, you'ld most likely have a puddle under the car. If the thermostat sticks shut, you over heat, if it sticks open, you never get hot enough...
When you have luke warm heat, and the overflow tank is bubbling over, what does your temp gauge read?
