I own a 2000 Maxima SE with now 160k miles.. (Purchased last year with 129k)
First purchased, I replaced 6 plugs (NGK Platinum) car still developed an erratic idle, and almost stalled every cold morning, which led me to buy new coils (OEM) which solved that problem.
Purchased and installed New MAF sensor (OEM from Nissan) which helped some it seemed with power, but it would slowly go back to milder, or less acceleration the more start-ups i had and drive cycles.
I also had a New bank 2 Pre Cat O2 sensor installed by mechanic, which surprisingly made me notice a good deal of some power restored. I then replaced Bank 2, or front Pre Cat as well (Cat Efficiency code for inspection) since then, the p0430 just keeeps popping back up within 100 miles or so, sometimes less..
Pissed off at the lack of power and acceleration again, and resulting hesitant downshifts when attempting to pass/accelerate..
I disconnected the 2 oxygen sensors (Pre Cat) and to my surprise, got a Great Deal of acceleration back it seemed! The car downshifted better at stop signs when immediately going to accelerate again through it, passing and pick up speeds were greatly increased, and smoother!, and a much smoother idle (wasn't super erratic in idle before, but noticeable)
Any Ideas??? Is this telling me one or both of my o2 sensors are bad or sluggish? causing performance issues? I never had the supposed ECU upgrade/Flash after installing the new MAF sensor either...
Any thoughts on the matter?
Sincerely,
Love this car but going NUTS trying to figure this thing out!
