Let's don't even discuss thissjoy wrote:I read a post some months ago about someone cleaning carbon buildup by somehow feeding a gardenhose and dishwasher soap into his engine while running. Is this idea rediculous or genius?
Are you trolling us?sjoy wrote:I read a post some months ago about someone cleaning carbon buildup by somehow feeding a gardenhose and dishwasher soap into his engine while running. Is this idea rediculous or genius?
Okay, good.sjoy wrote:The plugs are OEM and top of the line as far as I understand it. They are the same as I pulled out of the car when I purchased and I think those were the originals. The air filter is just paper I think.
Well worth it! Only one thing ... it is BG44K, just mentioning it in case a search for the other name fails.sjoy wrote:I'm going to try to import some GB44k into New Zealand. It gets quite a bit of praise on the net.
Uh ... okay ... but I remain skeptical. I don't plan to do it to my engine ever.sjoy wrote:I read about the garden hose and soap idea on another forum. Apparently it worked quite well from what I remember. The guy kept the vehicle at a low idle and bit by but dribbled a soapy water solution into the engine somehow - through his fuel injectors initially I believe. He said the secret was to use very little soap and water at a time. I tried to track down the thread but couldn't.
This was an old fix on carbed cars, you dribble water straight into the carb and it vaporizes in the engine, and theoretically cleaning the carbon off with steam.sjoy wrote:The plugs are OEM and top of the line as far as I understand it. They are the same as I pulled out of the car when I purchased and I think those were the originals. The air filter is just paper I think. I'm going to try to import some GB44k into New Zealand. It gets quite a bit of praise on the net.
Cheers
Does the term hydrolock mean anything to you?sjoy wrote:I read a post some months ago about someone cleaning carbon buildup by somehow feeding a gardenhose and dishwasher soap into his engine while running. Is this idea rediculous or genius?
