2 quick questions...
Tonight, on the way home, my brake light (on the dash) came on for about 10 minutes, then went off. Not the ABS idiot light, but the brake light (as if the E-brake was engaged).
Any thoughts?
Also, since I had the plenum pulled and 2 injectors replaced 2 weeks ago, now she idles REALLY rough when cold... Like when I start her up, she's smooth, then about 30 seconds afterwards she starts to LOPE like a musclecar. Once temp gauge starts to climb, she smooths out, and warm idle is beautifully smooth. I'm not noticing a loss of power or hesitation, it's just the cold idle.
Any thoughts?
1qckser
Car: my wife, daughter, q45T,G20T,SE-R
When my SE-R did the brake light thing it was a diode in the alternator going bad, and for the idle problem could be one of the injector o-rings are not seated correctly but when the engine temps get up the rubber expands and the leak is sealed, had this happen on the Sentra as well when I went to a larger injector, hope this helps.
PalmerWMD
Car: 2004 350Z
The brake light also doubles as a lbrake fluid level indicator.
Even if it seems full, topping off has fixed smiliar problem for me on previous Q.
Fred..:)
DAEDALUS
Car: 1990 Infiniti Q45
Brake fluid might be a tad low, jostling the fluid might be setting off the light, plus change in volume with change in temp. I agree with 1qckser--for the rough idle check for an injector leak.
Got it - The service guy's gonna be pissed, but he got paid, so that's that.
I'll have him check it out.
