Qdog »
https://forums.nicoclub.com/qdog-u384.html
Sat Nov 01, 2003 6:46 am
This may not be the cause of your rough idle, but a fuel leak needs fixing ASAP. Take the metal cover off the top of the injector, wipe it off, then let it pressurize and look for the leak. Hopefully the injector won't fly out of the rail from the pressure ! That would save some work, since they are a MF to remove from the top. You will probably deform the plastic where you grab it with a pliers, be careful and maybe you can re-use the injector. Get new O rings (please), put a light silicone grease on them, and press the injector in without twisting ! If you twist it, the O rings will distort and leak badly ! VERY IMPORTANT: relieve the pressure in the fuel rail before removing the injector. Pull the fuel pump fuse while the car is running, let it die, try to restart, then open the gas cap to relieve any remaining pressure. I found that pressure can develop after this procedure with the car just sitting ! Don't ask how I know this... You might want to drain the fuel rail from the crossover hose in front. The last thing you want is to allow fuel to gush into the cylinder when the injector is removed. This could cause hydrolock & serious damage when you crank it over. Good luck.
