jfanaselle »
https://forums.nicoclub.com/jfanaselle-u73887.html
Tue Mar 18, 2008 4:31 am
A 4 channel amp would still require two sets of rca jacks (4 rca plugs total) on the head unit to function properly. 4 channel amps basically act as two seperate two channel amps, in the sense that they will have two independent sets of inputs and controls (usually), but will only require one connection to power.
Splitting the rca jacks on the head unit is a possibility, but you're going to experience half of the voltage at the amplifiers from the car stereo. If your pre-outs are rated at 4 volts, this probably won't be a problem becuase you'll still end up with 2 volts at each set of inputs on the amp(s). If your head unit is rated any lower than 4 volt pre-outs, then I probably wouldn't go that route. If you do decide to split them, I would recommend making the split as close to the amplifier(s) as possible, to prevent running an already weakened signal a long length with two seperate cables.
Another option would be to simply run multiple sets of speakers off of your amplifier. I used to have a setup like this in my old Mazda Protege.As long as your amplifier is two-ohm stable, you won't have any problems connecting a front and rear speaker to each of the left and right sides. Typically in this type of setup, the output wattage of the amplifier doubles because the resistance is cut in half, so you shouldn't experience any weaker sound. The only drawback is that you'll usually experience more THD (total harmonic distortion) from the amp in this type of setup, but I guarantee that it won't be noticable to even the most trained ears, only a scientific measuring instrument.
The final way you could run it is to simply power the rear speakers from the head unit. This is how I have my car setup right now. I have a 75 watt RMS x 2 channel amplifer powering my Polk Audio components in the front, and the rear Sony 2-way speakers are being powered by the head unit. Most of the time, I have the stereo's fader adjusted all the way to the front, so I don't hear anything from the rears (taking a page from Kolk1's book here ) but when I have rear seat passengers and they want to hear something other than my subwoofer, I adjust it so there's some sound in the rear for them.
Hope all that info helps. If you decide to run any of these setups and need more help, just let me know and I'll do my best to answer your questions. Good luck with the install!
